When I try to append two AVI files I get the following error.
The information on the two files are below
To me the files look the same but..... What do you guys think?
Sorry about that..... Mistake on my part. I have the correct information on it now. Thanks for the quick reply.
Originally Posted by monteieOriginally Posted by Baldrick
Another classic deadpan from HRH.
I'd say that the different video bitrates is causing the problem. Is your end goal just to have this as one big AVI, or are you looking to convert to VCD/SVCD/DVD ?If in doubt, Google it. -
Different bitrates don't matter. I remember when there was a bug with XviD where when you enabled a forced I frame for a zone it made all frames I frames instead of just the first so my end credits ended up too big despite the high fixed quant.
I redid the credits correctly and was able to join a much lower single pass fixed quant file with a higher bitrate two pass VBR file.
AVIMuxGUI would be another one worth trying.
Just out of interest, what build of XviD do you have installed? -
Can you guys point me to resources where I can find out how to join files using the programs mentioned.
Problems with Appending AVIs
By wmseith in forum Newbie / General discussionsReplies: 1Last Post: 22nd Sep 2010, 13:15 -
Appending Videos
By dkern in forum Newbie / General discussionsReplies: 0Last Post: 6th May 2010, 14:36 -
Appending .srt in .sub
By kyrcy in forum SubtitleReplies: 1Last Post: 19th Dec 2009, 03:46 -
VirtualDub Appending Issues?? (Pix Inside)
By sandman423 in forum EditingReplies: 4Last Post: 7th Feb 2008, 06:01 -
appending avi segments w/virtualdubmod
By burgkev in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2007, 13:14
