ok you tell me...
my pc: AMD 2400+
768Mb DDR333 RAM
Windows XP SP2
Dvico HDTV DVB-T
Geforce Ti 4400
my setup: (video only, i have no problem with sound so i won't mention it) Foxtel digital set top box connected via Scart to S-Video in of Dvico card (analogue in). S-Video out from Geforce card to S-Video in of TV.
my software/codecs:
K-Lite Codec pack 2.52 Full (installed with default settings)
Dvico FusionHDTV3.0.01Web.exe + Hotfix30003.exe
my goal: to capture the video from the S-Video in using a program that has a scheduler (like a timer on a vcr) and later play it on the pc and watch it on the tv like i do with movies.
my problem: there is no software that can do this well.
i have used about 7 or 8 programs now in an attempt to do what should be a simple task. the closest i have come to a decent result was with a program called WinVDR. it captured in Xvid with great quality but the program caused all sorts of things to happen ie: the computer would reboot for no reason during capture, it would capture for 2 hours and when the file was played back it was only 45 minutes long and the audio cut out after 8 seconds. (these happened seveal times all using the Xvid codec) other codecs gave poor quality video.
so i am just about to kick the crap out of my computer. i am so frustrated. every forum i read praises programs like Chris Tv, but i found it to be useless for my needs. other programs like GBPVR didn't even recognise my analogue input.
i just want to use my pc like a VCR and record from the analogue input the easiest way possible with a reasonable quality result. is this possible with my setup? if so how?
thanks in advance.
To the computer, installing the codec pack was like swallowing a gallon of strychnine.
I don't know anything about your set up so can't help there but I can tell you that I have a Hauupage 150 video card and use Beyond TV to schedule, record, and playback TV and it works well.
Actually I have 3 cards in one computer so I can record three shows at once. I won't claim it's perfect, right now I'm trying to figure out why I occasionally files with size zero, but it is not too often. -
ok so i've now uninstalled the codec pack and just installed the codecs i need. i was actually kind of hoping for some suggestions other than just telling me i've poisoned my computer.Originally Posted by lordsmurf
That's all the time I have. What you want requires a lot of time I don't have. I just gave a brief nugget that was required, which was to warn you about the codecs.Originally Posted by kotton
And, sorry to say, uninstalling may not fix it. A lot of people end up having to re-format the hard drive to fix codec errors. You can also try manually attacking them with DXMAN or similar.Want my help? Ask here! (not via PM!)
Looks like at least one person is able to capture analog TV with that card:
https://www.videohelp.com/capturecards.php?CaptureCardRead=431
Analogue to Digital capture software
By ManUtdFans in forum Capturing and VCRReplies: 9Last Post: 16th Jun 2011, 12:10 -
PCIe 1x slot, TV with analogue Capture required
By max_e_mum in forum Capturing and VCRReplies: 0Last Post: 10th Oct 2009, 00:26 -
Analogue Capture problems
By Lensmeister in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2009, 06:20 -
Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?
By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 19:29 -
Analogue Capture
By Sonnyt in forum Capturing and VCRReplies: 3Last Post: 26th Mar 2008, 20:49
