I have several avi files that i wanna put on dvd and make dvd-like menu so i can use it when I play disc in dvd/divx... stand-alone player. I would like to avoid file resampling that happens when you make video dvd, so the files stay into same avi format. Is that possible? And if it is, what software should i use for making a menu?
please use our search, i tried search for divx menu
https://www.videohelp.com/forum/viewtopic.php?t=271635&highlight=divx+menu
https://www.videohelp.com/forum/viewtopic.php?t=276430&highlight=divx+menu -
Not possible with avi, but it is possible as suggested with .divx. As stated in the threads though there is currently no hardware support and by the time there is who knows you might be able to do it with mkv. The advantage of .divx though is that since it is based/hacked on avi if something doesn't support advanced features like menus it will just ignore them.
So if you create a .divx file now, the file will still play on your current standalone, just without menus. In the future if you got a new player (or there was a firmware update) the menu would start working. -
Ok, thanks for info. Could you just tell me how to make menu for .divx file. What software do you suggest? Also how to convert .avi to.divx?Originally Posted by celtic_druid
How to play AVI videos on a DVD through a Menu?
By ConverterCrazy in forum Video ConversionReplies: 13Last Post: 26th Apr 2010, 23:28 -
How to make a compilation of 4:3 videos and 16:9 videos together on a dvd?
By pedrotc2002 in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2010, 18:35 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 10:07 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 15:29 -
how do I make a DVD with Divx or Xvid videos and have a menu that works
By Onceler2 in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 20:14
