I am unable to view mpg files using pinnacle studio ver9
i can view avi and jpeg but not mpg. I have loaded klmcodec packs 137 & 253f onto my system but still no luck......any ideas???
The attached pic shows that i can view avi & mpeg1 but not mpeg2
are ther any codecs or patch for this problem
cheers
Hellman[/b]
What pic ?
Sounds like you need an MPEG-2 codec ...
PowerDVD supplies its own, but there are others in the Tools section that may help:
https://www.videohelp.com/tools?tool=Stinkys_MPEG2_Codec
https://www.videohelp.com/tools?tool=GPL_MPEG-1_2_Decoder
https://www.videohelp.com/tools?tool=ffdshowIf in doubt, Google it. -
I had the same problem and when I called support, they gave me the key to unlock MPEG 2.
If at first you don't succeed; call it version 1.0
Pinnacle - work in SD and finished output in HD?
By Ronan Carley in forum EditingReplies: 2Last Post: 31st Jan 2012, 09:24 -
Will Pinnacle Studio9+ work with Windows 7???
By rrtbusa in forum Capturing and VCRReplies: 0Last Post: 14th Dec 2009, 19:06 -
Pinnacle 12 and Boris
By romanticwarrior in forum Authoring (DVD)Replies: 0Last Post: 15th Jul 2008, 12:43 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 18:02 -
Pinnacle 11
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 3rd Apr 2008, 02:08
