  1. I'm using power dvd and when I play my dvd I get skipping and static when I paly my dvd please help. This is on all dvd's played.Thanks
    mickey
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Maybe your DVD-ROM is struggling to read your DVDs ?
    Have you tried re-installing PowerDVD ?
    Tried playing those same discs on a friend's PC (with or without PowerDVD installed) ?
    Are these DVDRs you've created yourself or pressed store-bought discs ?
    If in doubt, Google it.
  3. Thanks, I get the problem with bought and back-up dvd's The video is fine but the audio skips and a lot of static. Iget the problem with windvd and windows media and power dvd. Any thougts. Thanks.
    mickey
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If it's happening with storeboughts as well then it points towards your DVD-ROM possibly being on the way out, a corrupted audio codec, or maybe even something dodgy with soundcard and/or speakers. I would have thought that each software would use it's own AC3 Decoder (PowerDVD definitely should), but you could try installing AC3Filter and see if that makes a difference.
