I have installed this program on 3 XP machines. It used to work on 1 or 2 of them - now the choice never offers itself in the right-click context menus.
The files are named *.MPG, they play with WMP.
I have over 40 entries in the registry when I search on "mpegfile" - too many to investigate as I am not a registry expert.
Any ideas would be welcome.
Any way to run it directly and force it to deal with an MPG from the command line ?
Anyone else have this problem ?
TIA, P-PA![]()
Hi, I have the same problem, it's not showing in the context menu. I tried with .mpg, .mpeg, .mp4 and .avi w/o success. I checked the registry and there was an entry for the .mp(e)g file type (which I copied to the entries for the other mentioned file types) but it's not working at all.
I can get it working if I right-click on the file, go to 'Open With' > 'Choose Program...' then click 'Other' and browse to the MpegDetails program. Then I can see the details and preview the material.
I'm using Windows XP SP2 and I'll try it this week on Windows 2K also. -
I haven't visited this tool for a while (it could do with an update....)
But it goes like this:
You should have a registry entry for the mpegfile type as follows:
(this is created when the program is installed)
Then all extensions which are applicable should have the mpegfile set as the default:
(HKEY_CLASSES_ROOT\.mpg)
some are there be default: .mpg, .mpeg but you can do it for others like .vob etc.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Yes, I have this, but it's not working, don't know why.
I just created a shortcut in my Send To folder and this works like a charme and is also much simpler then adding several keys to the registry.
The program works fine now including previews with subtitles.
Thanks for your help.
foobar2000 1.1.3: context menu only on some folders - why??
By flashandpan007 in forum Software PlayingReplies: 5Last Post: 19th May 2013, 10:29 -
MediaInfo Context Menu
By drgt in forum Newbie / General discussionsReplies: 1Last Post: 31st May 2011, 15:48 -
R-click context menu for VLC and WMP - not working
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 16th Nov 2010, 07:44 -
[Vista] Sound file context menu/other issues
By Ai Haibara in forum ComputerReplies: 0Last Post: 4th Mar 2009, 01:40 -
Item missing from Windows Context Menu
By alegator in forum ComputerReplies: 4Last Post: 19th Sep 2007, 17:12
