Hey,
I have a VCD that I have converted to a AVI(DiVX) file in order to add subtitles to it. I have 2 AVI files named 1.avi and 2.avi and 2 subtitle files called 1.ssa and 2.ssa. I installed VobSub and the subtitles show perfectly in Windows Media Player. I then used TMPGEnc to encode the AVI files into VCD format with permanent subtitles (I have the Directshow Multimedia Reader plug-in installed). But whenever I do this I get a lot of audio noise. Is it because I'm going from DiVX to VCD? I tried seperating the audio from the video and I used the .wav file I got but I still get the same noise after encoding it in TMPGEnc.
How do I solve this problem?
Thanks!
There is by far more elegant way to achieve this, but it depends if your DVD player can play non-standart SVCD's (mpeg1video) with selectable subtitles.
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 05:12 -
adding subtitles to AVI (xvid or divx) WITHOUT re-compressing
By truthlesshero in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 11:43 -
adding subtitles to avi file
By dragonhead08 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jan 2009, 09:18 -
Adding Subtitles to divx w/ a .sub file
By sean2a in forum SubtitleReplies: 5Last Post: 28th Sep 2008, 17:23 -
Adding Subtitles To An .AVI File
By thesal523 in forum SubtitleReplies: 2Last Post: 10th Aug 2007, 13:16
