I jsut purchased a pack of 5 Vakoss DVD-RWs from Staples... However when I attempt to format these discs I get the message these disc are "write protected, please unlock...." I know you can write protect DVD-RAM discs but not DVD-RW....
Any suggestions....????
Looks like you purchased 4X DVD-RW media instead of 2X. Your recorder cannot use 4X DVD-RW media for recording, better exchange them for some 2X DVD-RW media.
Thanks for the reply...but Memorex and Maxell DVD-RW I've been using are 4x.... The manual also mentions 2x and 4x can be used....
Where did you get Maxell 4X DVD-RW media in the first place? I've only seen Maxell 2X DVD-RW media available so far. If your model is actually the D-R2, note that 4X DVD-R is not the same as 4X DVD-RW. Is the model of your recorder D-R2 or the newer D-R4? There is a big difference between these two, and 4X DVD-R is not the same as 4X DVD-RW as mentioned before.Originally Posted by kenmo
toshiba sdp95swb
By paul72 in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2011, 05:51 -
toshiba sd2010
By kibz in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2010, 01:58 -
Toshiba RD-XV48DTKB
By GT40 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Aug 2010, 08:36 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:57
