This don't really have anything to do with DVD's but i have a 27 inch Apex TV it's about 2 or 3 years old and the picture is getting smaller there is a half an inch of black space on the right side of the TV and on the left it's more than that. It's hard to explain theres a half of a inch black space then you see picture. I don't think there is any settings where you can move the picture do newer TV's have that, i know the old ones did.
Results 1 to 10 of 10
I think a hardware piece becomes defective. Probably the power supply of the screen
Get some fan subbed anime. You'll be happy the TV doesn't overscan and you can see the subtitles!
I first noticed it when it would cut my dvd menus off some. It does the same with text on the news it will cut a letter or two off. On my other TV you can see it just fine.
You guys think it's hardware? I new i should have never bought Apex TV. -
If it is doing it for normal TV stations, then it is hardware, probably loosing the high voltage supply.
http://www.kiva.org/about -
Ask your local TV repair shop.Originally Posted by David9799
BTW: 2 or 3 years on a Apex is doing good if your read the Epinions site.
Next time check user reviews.Recommends: Kiva.org - Loans that change lives.
A shrinking picture could be dropping high voltage but I have also seen situations in which the deflection yoke comes loose and slides back on the CRT tube neck causing the same.
Do you see the test pattern that edDV uses below his handle? Test the TV with a pattern like that and see if it the circles distort or if they remain circles. Generally, circles remain circles if the problem is high voltage or yoke. If there is distortion, it may be a horizontal sweep related issue. -
LOLOriginally Posted by junkmalle
I nearly choked on my soda when I read that you bastard!
I got soda all over me!
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 17:41 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 09:46 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00
