I've downloaded the new ffmpegx and ended up creating the Lib/Application support/ffmpegx folder because i kept getting errors when i tried to "locate" mpeg2enc, mencoder and mplayer. now it keeps asking for me to install mpeg2enc even though it's in the folder. it finds mencoder and mplayer...what's the deal? does the mpeg2enc file need to have a specific extension?
by the way, this is the error i get when i try to locate the mpeg2enc:
" ##/bin/sh: -c: line 1: unexpected EOF while looking for matching `''
/bin/sh: -c: line 2: syntax error: unexpected end of file "
This error seem possibly a special character in your OSX login password?
Concerning the mpeg2enc warning, check if your file has a size of 188524 bytes. If not, it is a wrong file. Get it again from http://homepage.mac.com/major4/download.html
install issues
By spiro murray in forum ffmpegX general discussionReplies: 1Last Post: 14th Mar 2009, 19:17 -
Install issues
By orkman in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2009, 09:05 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
Trial Version of Video Studio 11 hot fix issues, how do I install??
By JediPM in forum Newbie / General discussionsReplies: 8Last Post: 6th Feb 2008, 13:00 -
Code-lock Install Issues v2.5
By PhysicsMatt in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Jan 2008, 12:32
