I have two SATA Hard drives. I wish to format my other hard drive. However, I keep getting this error message when i try to format it through My Computer (right click and format):
Does anyone know how to format the Hard disk from within windows and without having to restart the PC.
Thanks.
More info:
Hard drive 1 (With OS): 160GB Seagate SATA
Hard drive 2 (to format): 74GB WD Raptor SATA
Try Control Panel>Administrative Tools>Computer Management>Storage>Disk Management. I use that for formating, partitioning and changing drive letters within Windows.
But if some program is accessing the disk, you should try to shut that off.
Restarting in safe mode would be the next thing to try and reformat there. -
You could also boot to the XP cd and prepare to install it. Format the disk, and then quit the installation. Just be sure to use the correct drive.
If you have a Windows 98 boot disk, you could also boot to that and run FDISK and format it as FAT32, and then convert it inside of Windows.
Like redwudz said try disk management first. It doesn't sound like the disk has been initialized. If it hasn't, the Disk Initialization Wizard should open up as soon as you click on Disk Management. -
Thanks for your help guys. Using the method suggested by Redwudz is working. My HD is being formatted as im typing this post.
Hard Drive: 80GB VS 500GB. Defragmenting and formatting speed.
By vid83 in forum ComputerReplies: 36Last Post: 6th Feb 2012, 13:58 -
Fat32/NTFS External Hard Drive Formatting Questions.
By bbanderic in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2010, 21:13 -
Hard Drive Formatting Problem
By Captain315 in forum ComputerReplies: 13Last Post: 21st Mar 2009, 09:44 -
Hard Drive Formatting?
By Invader Bugs in forum ComputerReplies: 7Last Post: 6th Mar 2009, 03:01 -
After formatting my new Hard Drive went down from 250GB to 127GB !_FIXED_!
By fLYtRap in forum ComputerReplies: 23Last Post: 19th Jun 2007, 09:17
