A friend has transfered some old VHS film onto DVD for me using the Sanyo DRW-1000.
Unfortunately it won't play in either of my DVD standalones and when I try to view the files in windows it just says "unknown file format"
I've just read through the online instruction manual and I'm guessing he hasn't finalized the disc. I've just spent over 2 hours searching the internet to see if anyone else has had the same experience and found a way to view and grab the video for re-burning... but no luck
It would be a great help if someone here knew of a way. My friend is in the US and I'm UK. He's very busy and I feel cheeky asking him to re do it when it's took him over 2 months to do this one![]()
Any help would be greatly appreciated![]()
Results 1 to 11 of 11
I would see if any store in your area has one of these Sanyos. Tell them what happened and see if they will let you come in and finalize the disk. It only takes a few minutes.
Originally Posted by jimmalenko
I firstly extracted the biggest file to a .tao file then from that file had the option to extract as an .mpg, which I did but the resulting .mpg is 0 bytes.
Originally Posted by lumis -
I seem to recall reading somewhere that DVDDecrypter can finalise discs.
If in doubt, Google it. -
DVDDecrypter reports "disc is empty". Even though I know that's not the case.
*edit> I'm just trying something else.... -
Progress!
I've found if I load the previously made image, right click and select "Find missing files and folders" it recovers the vob files. Yay!
Only trouble is it won't let me extract them without paying the registration fee
Now I'm not a cheapskate but I don't really want to pay for something that I probably will never use again. Is there a similar application that'll do the same job for zero moolah? -
Ok, after much frustration trying other tools that didn't work I caved in and purchased the full version of IsoBuster.
I now have 4 recovered vob files and after searching the "how to" section I found this: https://www.videohelp.com/forum/userguides/120021.php
Could someone tell me if that is the easiest way to get the file structure I need to re-burn to DVD, or is there an easier way?
Thanks.
Price level on (almost) new Signvideo DR-1000 and Datavideo TBC-1000
By Northpole in forum RestorationReplies: 3Last Post: 24th Jan 2011, 12:02 -
Help with Corrupt mp4 video files. from Sanyo WH-1
By Jmiller0921 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 31st Mar 2010, 22:27 -
Burning 1000's of files to multiple dvd's
By lordhutt in forum ComputerReplies: 12Last Post: 14th Dec 2008, 15:45 -
Sanyo Xacti HD-1000 and Toast 9
By farfel81 in forum MacReplies: 0Last Post: 2nd Jun 2008, 19:12 -
Unplayable dvds made on Sanyo DRW-500
By ronl44 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Dec 2007, 12:25
