I am converting an avi file to PAL 25 fps 16:9 format. but everytime i load up the finished file in DVD-LAB pro for authoring, it reads it as NTSC format. It never happened before with other files and i double-triple check to make sure TMPGenc settings are right and tried again and the same results. whats going on?
humm someone had a simlar prob... when you load up the avi in tmpeg... go into select source range & see what tmpeg sees the frame rate as if it says 30fps then you gotta alter vfpi**?
?? settings..
COOKIEEE!!!
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 02:59 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 07:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 17:47
