ive been having problems with many conversions lately....they stick at spots on my phillips 642 and my samsung....apex and pc run through fine....i am going to try the new build...i just wanted to ask if this has been an issue with anyoneelse using rc9b and if so...has it been addressed?
looter
:edit - BTW....upon verifying compilation in nero.....it slows down to 100bytes or so and states many read errors
could it be a nero problem? i got the new build and am rerunning one through right now
i like the new features so far...2 questions
what is the dl box under the autofit button and what does low bitrate matrices mean?
DL box is checked if using Dual Layer DVD's.
For matrices see: https://www.videohelp.com/forum/viewtopic.php?t=277580 -
thanx....i ll look into it later.....but i did figure out that it is either my burner or nero that is sticking the dvds.....i jus upgraded nero
Also look into what media you are using. Some brands exhibit errors when used in certain burners. Just came up against a spotty batch of Riteks, of which I'll never buy another
Cute video of Kitten sticking her arm out of box hole!
By peggypwr1 in forum Off topicReplies: 0Last Post: 27th Jul 2011, 21:52 -
Sticking subtitles in mp4 videos
By kaz219 in forum SubtitleReplies: 4Last Post: 19th Jan 2010, 20:19 -
Best conversions for dvd
By atvmxr in forum Video ConversionReplies: 5Last Post: 22nd Apr 2008, 09:47 -
What is the difference between these conversions?
By neo_74 in forum AudioReplies: 2Last Post: 3rd Jan 2008, 19:42 -
Tevion 8001 HDMI DVD player - disc sticking/freezing problems.
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:50
