today i bought the dvd movie brotherhood of the wolves from a discount dvd store but saw at home that it is in french, i want to add english subtitles to the movie, i tried to read couple of threads here but could not figure it out. Could somebody be kind to point me out if there is a step by step explanation here or maybe write here?
thanks alot
Does the dvd feature English subs?
“He who makes a beast of himself gets rid of the pain of being a man.” -
Its kind of complicated but it works, Ive done it myself.
https://www.videohelp.com/forum/viewtopic.php?t=275603
Use PGCEdit instead of IfoEdit for step 9 in the guide. -
You will have to search the web for a subtitle file for your movie, i'ts a bit hit and miss depending on the popularity of the movie, i had to find a sub file for La Haine not so long ago and found one, though i can't remember the name of the site that had it off the top of my head.
Post back if you find something you can use.
EDIT
This site has the file you need.
http://www.extratitles.to/?p=se&z3=B
You will need to unzip the file with winrar and then follow some guides.
Hope this helps. Peace.
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31 -
Need help adding a subtitle to a DVD.
By chris4556 in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2011, 22:12 -
adding watermark as a subtitle
By zammil in forum SubtitleReplies: 8Last Post: 20th Nov 2010, 01:45 -
adding subtitle
By Rezadarius in forum ffmpegX general discussionReplies: 1Last Post: 9th Aug 2008, 05:45 -
Adding a subtitle for a DVDR
By rotchild in forum SubtitleReplies: 5Last Post: 28th Jan 2008, 12:07
