I have some xvids which are 4:3 and 16:9 which I converted to vobs using DivxtoDVD in order to burn onto a DVD disc to watch on my widescreen TV.
The problem is that when I watch it on my widescreen, the picture is zoomed in too much, the outer edges of the video are off the screen. This applies for both the 16:9 vobs and 4:3 vobs. Now I did try the different aspects on my dvd player settings - 16:9, 4:3 pan&scan, 4:3 letterbox. It is still too much zoomed in. Also, when Im in component 1 on my tv, I cannot change the tv's aspect ratio. Also, the zoom out function on my dvd player doesnt help at all, because I'm already zoomed out as much as possible.
Here is the configuration of the converted VOB file for one of the 16:9 videos:
Player Information:
Player Region Code: 1
Current Drive: D:
Title Region Code: 1, 2, 3, 4, 5, 6
Display Information:
Video Mode: Weave
Display Mode: DirectDraw
FourCC Code: YUY2
Surface Type: Overlay
Video Attributes:
Video compression mode: MPEG-2
TV system: 525/60 (NTSC)
Aspect Ratio: 16:9
Display Mode: Both Pan&scan and Letterbox
Source picture resolution: 720x480 (525/60)
Frame Rate: 30.00
Source picture letterboxed: Not letterboxed
Bitrate: 2.62Mbps
Subpicture Attribute: Not Available
Hardware Information:
Processor: AMD Athlon(tm) 64 FX-53 Processor running at 2411 MHz
3DNow! Technology: In Use
Enhanced 3DNow! Technology: In Use
3DNow! Professional Technology: In Use
IA MMX Technology: In Use
IA Streaming SIMD Extensions: In Use
IA SSE 2: In Use
Video Accelerator: DirectX VA (not in use)
Multispeaker Audio Device: Realtek AC97 Audio (not in use)
SPDIF Output Device: Realtek AC97 Audio (not in use)
Here is another configuration for the 4:3 vob file:
Player Information:
Player Region Code: Not Specified
Current Drive: D:
Title Region Code: Not Available
Video Mode: Weave
FourCC Code: YUY2
Video Attributes:
Aspect Ratio: 4:3
Display Mode: Only Letterbox
Frame Rate: 30.00
Bitrate: 5.01Mbps
So as you can see, I've tried all 3 aspect settings on my dvd player's settings and the video is still too zoomed in. Is there something I need to edit in the .IFO files or am I missing something? Note that my dvd player can't read xvids, which is why I had to convert them to DVD compliant files.
Thanks in advance, and sorry for the long post.
Ok I see that you can use some programs to add black borders around the xvid file to compensate. However, this would require that I re-encode the xvid, then convert it again to vob. Is there a way to directly edit the vob file?
Player for watching .flv files
By jbandy1 in forum Video Streaming DownloadingReplies: 5Last Post: 1st Aug 2012, 10:21 -
various movie files converted to play on dvd player
By SPORTSGUY88 in forum MacReplies: 4Last Post: 3rd Aug 2010, 11:25 -
Audio becomes out of sync when converted (transcoded?) from .vob files
By Neptuna_Fish in forum Newbie / General discussionsReplies: 12Last Post: 21st Aug 2007, 20:39 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 19:26 -
Cannot play Avi files converted to DVD on my DVD player.
By callmejr2 in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 11:19
