I encoded a 23fps movie to 25fps for burning to dvd using diko, the problem is that the vobs in the video_ts folder do not play back properly, the video is fine but the audio is too fast, it sounds like chipmunks talking through the movie, is there a way of isolating the soundtrack to get it playing at the right speed and in sync using the vobs i have? I have used diko many, many times but have never had this problem.
“He who makes a beast of himself gets rid of the pain of being a man.”
Extract the audio seperately and use something better to change the sample rate. I have seen this occassioally when going from 22khz to 48khz, and it is usually the software at fault. I know Sound Forge does not exhibit this problem, but occassionally SoftEncode does. You need to make this change before DIKO get's it's hands on it. Afterwards the damage is done.
Read my blog here.
Fast, HQ MKV Conversion? (Paid/Free possibly using CUDA)
By Pyrophoric in forum Video ConversionReplies: 7Last Post: 13th Jan 2012, 05:57 -
After MPEG-PS conversion, beginning of the video is extremely fast
By killazys in forum Video ConversionReplies: 7Last Post: 24th Jun 2010, 01:22 -
Recomended Software for fast simple compatible capture and conversion
By The Turtle in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2010, 16:10 -
Fast .ts > .mkv conversion
By NewbieCanuck in forum Video ConversionReplies: 4Last Post: 3rd Feb 2009, 12:05 -
.MTS to .avi conversion (video seems fast)
By puncho in forum Video ConversionReplies: 9Last Post: 12th Sep 2008, 02:49
