how can i fix mpeg errors? like there are glitches in the mpeg stream. and whenever i use tmpgenc express, the part where there is an mpeg error freezes the whole mpeg (even though the audio stream is still working)
You could try using something like virtualdubmpeg or virtualdubmod to remove the glitched section, but really there isn't much you can do other than download / capture it again.
Read my blog here.
If you know where the freeze occurs then you can cut it out.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by guns1inger
you see, i got those videos from overused vcds - changed it to mpeg using vcdgear (even it says it 'fixes' the stream - it really doesn't). then when i want to reauthor the mpeg into another vcd using tmpgenc express (i was planning to make it into a single mpeg video, rather than mpegs), when the process of encoding the video into one file, the picture of the video freezes into that certain point. that's it - the rest of the mpeg is that part of the video, then if it is time for the next mpeg, the video is fine.
how will fix the mpeg error. it's ok, if there are glitches. i have those videos, some are even much erratic but when processing it into tmpgenc express and videocd, it looks fine. sure when playing the video, there are pixelations, but it does play.
so...help!!!
is cutting the only way?
Scanning and fixing m2ts file errors?
By Killingtime01 in forum Blu-ray RippingReplies: 2Last Post: 10th Oct 2011, 17:05 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 22:55 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Fixing troublesome mpeg files?
By Hatecrime69 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:41 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
