wow this is making me so mad im almost crying. im having big problems with getting mpeg2 files to play in windows media player and be able to open up in tmpgenc. what i need ot know is a list of coedc i shoudl have installed. i need ot be able to record and encode and sue tmpgenc and wheveter else it is you do.i can have it playing fine in WMP but then it wont open in tmpgenc. or it plays sound in WMP and no video but opens in tmpgenc. or it just wont work at all. ive used some nimo coed pack and klite codec pack only installing once to do with what i need.
please help be this is makign me cry. wow this sucks. so what i think i need is mpeg2 codec files and mpeg 3 layer audio. please help. i also have the stinkys mpeg2 codec intaller thing but its not working proper giving me an error when trying to uninstall but someitmes it will work.
so it would be nice if i could get some help quick with this as its so frustrating.
thankyou so much.
Results 1 to 10 of 10
1. uninstall every codec pack you installed as they are crap
2. make sure they are uninstalled completly - every last trace
3. reboot
4. install ffdshow"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yes i had uninstalled my nimo and klite codec packs. those are the ones i had tried. i did uninstalled ffdshow and installed the k lite codec pack and i can atcually get mpeg2 to play perfect but tmpgenc just wont open them. thats what i need to fix. and when i installed ffdshow i had everythign checked off so that isnt the problem.
just to let you all knwo i have a ati aiw 9600xt andi just installed the newest drivers and it started not working proper. and when i was uninstalling i sorta screwed up and it took me a long time to get it working but i think there is still a problem in the multimedia center. -
well ive got all my ati driver stuff sorted out but the mpeg2 aint workin. if i can just get that to work i will be so happy. i got no packs installed and stinkys mpeg 2 decoder thin uninstalled. now what do i install to get mpeg2 to work in windows media player and tmpgenc? ffdshow didnt seem to work and im not sure that VFAPI is what i need. if for some reason i cant get it to work to open mpeg2 in both WMP and tmpgenc ill just make it so it opens in WMP all though it shoudl work in both.
hope someone can help. -
well i got mpeg2 working in tmpgenc. i just downlaoded the tmpgenc mpeg2 plugin and it wokrs. later ill see if i can get the mpeg2 to work in WMP then evrythign shodul be good.
Problem Codecs Conflict
By MichaelMaher in forum Newbie / General discussionsReplies: 6Last Post: 1st May 2011, 07:14 -
Installing ffdshow to solve codecs problem?
By giunghi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2009, 05:42 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
audio codecs problem...
By cwb in forum LinuxReplies: 1Last Post: 13th Jan 2008, 15:12 -
New / problem with codecs
By AJ Martinez in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2007, 19:32
