Hi, i use DVD lab-pro for DVD authoring but this software only accepts SPC format subs. How can i batch convert SRT/SSA files to SPC/SP1 format?
I really don't understand why you need that. DVD-lab PRO can import SRT files without problems. I created a lot of DVDs with subtitles that way and the results are excellent.
Maybe you don't know how to import the SRT files. Just click in the authoring panel on button "Sub 1", which is located below the buttons "Chapters", "Audio 1" and "Audio 2". By default is just one button, but after first subtitle is created (in format *.SP1), another button with the name "Sub 2" appear. A new window open where you can import the SRT file and adjust a lot of settings. Is very simple.
[/img] -
yeh it is simple ...but really damn annoying
i have 8 episodes on each dvd and 12 dvds and to import you gotta do it 1 by 1 and each takes 2-3 minutes ...so i gotta sit there for about 20 mins just to import subs ...thats just not koo
which is why a batch conversion tool is helpful
later
-nomad311
Ogm to Avi, pick of audio track, external subs (batch job)
By 45tripp in forum User guidesReplies: 2Last Post: 10th Jun 2009, 16:53 -
Batch re-mux .mkv to DiVX w subs
By nbarzgar in forum EditingReplies: 6Last Post: 3rd Jun 2009, 06:18 -
Best Free App for TRP to MPEG format Batch Conversion?
By binar in forum Video ConversionReplies: 7Last Post: 16th Apr 2009, 22:21 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Batch remove audio/subs
By BVT in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2008, 12:58
