I'm trying to extract some audio from a couple files for use in conversion to VCD and DVD and Virtual Dub is giving me an error: No audio decompressor could be found to decompress the source audio format. (source format tag: 0055) I checked with AVIcodec and it comes up that the audio is regular mp3 format and is supported. Furthermore the files can be watched with no problem. If someone could help me it would be great. Thanks.
Hi Magikx21,
How are you trying to extract the audio? Describe what you're doing in VirtualDub.
What format do you want to end up with from VirtualDub?
It may well be VBR MP3 - have you tried OK-ing (ignoring) the error message and continuing?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
In VirtualDub I'm putting the audio into full processing mode, turning it to no compression and converting it to either 44 or 48. Then I just save it as a wav.
Also there is no clicking OK. It gives the error message as soon as I hit save wav and stops. -
Install the lame mp3 codec and then follow http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm .
If in doubt, Google it. -
After leaving the file sit for 2 months I figured out my problem. This problem must be something with Virtual Dub because WinAvi converted the file perfectly. I tried other converters and audio extracters and with them the audio always ended early.
MKV stream extraction causing audio sync problems
By PlanetIndigo in forum Video ConversionReplies: 18Last Post: 29th May 2011, 22:07 -
MP4 audio extraction (ripping the 5.1)?
By takearushfan in forum AudioReplies: 15Last Post: 13th Sep 2010, 08:12 -
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 11:03 -
MP4 Audio Extraction
By neumannu47 in forum Video ConversionReplies: 2Last Post: 28th Aug 2008, 19:17 -
5.1 audio channel extraction
By efiste2 in forum AudioReplies: 3Last Post: 15th Sep 2007, 04:05
