  1. I'm using EZ CD Creator 5 to burn my VCDS, but I want to upgrade the quality a little and make a SVCD. Can I make the normal SVCD like the VCD and then just burn that? Or do I have to use a different burning program? Thanks.
    Feb 2001
    Palmdale, CA
    use vcdeasy or nero.
    Dec 2001
    Easy Cd-creator is crap when u want 2 burn (S)VCD´s..
    Great with sound and so on, but...
    VCDEasy or Nero is the best..
