Does anyone have experience playing a double layer disc in a Liteon 5007 unit? All my commercial discs (apparently are DL since they are always over 6G) play fine in the 5007, but I want to backup some of my discs using my PC into either DVD+ DL or - DL and I am not sure if those would play back in the Liteon.
I saw some DL Verbatims at a good price so I am curious if I should give them a try.
Thanks.
B
In the DVD player list to the left over there, it says it won't play them. If you can buy just one, try it. I wouldn't buy more than one though, just in case. Those DL disks aren't cheap.
I am thinking about the same too. The Liteon website also says it can only play DVD+/- R/RW and CD. However, what confuses me is that why is it able to play commercial DL discs?Originally Posted by ebenton
Thanks for anyone who can shed some light into this matter. -
Commercial discs ae pressed not burned. Big difference...
*EVERY* DVD player can read commercial DL disks. (Now that I have said that, somebody will come up with one that can't.) DVD movies have been more than 4.7 GB for a long time. Pressing these disks at a factory (they don't "burn" anything) is much more precise that burning holes with a laser in layers of dye on a disk on your computer. "Home-burned" DL disks may not be as easy to read for some players. Looks like your Liteon is one of them.
Do Any Double Layer Disc Work With Panasonic DMR-EZ48V?
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 10th Jun 2010, 16:39 -
Burning Double Layer Disc
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2009, 09:22 -
How do I burn double layer disc with Nero 9
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2009, 06:13 -
Does Philips DVP 5990 play home burnt double layer DVD videos?
By indyram in forum DVD & Blu-ray PlayersReplies: 13Last Post: 28th Dec 2008, 11:06 -
How to burn 8.3G iso movie file to dvd double layer disc?
By ibearzz in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 20:47
