i been using the program for a few weeks on my computer now, but now i keep getting this error message when i load SVCD2DVD
Version: SVCD2DVD 2.0
Build: 2.0.2034.36335
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
Im using windows XP Pro Service pack 2
With the full working version of SVCD2DVD
ANY ideas ?
You might try, uninstalling S2D, & re-install.
You have latest version of .NET framework installed? Might check that too.
HTH -
Can you try deleting any dnb_xxxx.xml files in the SVCD2DVD folder to see if that resolves the issue?
Error loading .sup files to GfD?
By michcio in forum SubtitleReplies: 0Last Post: 13th Dec 2009, 13:08 -
error+restart while loading Premiere Pro
By pixiecate in forum Software PlayingReplies: 1Last Post: 22nd Oct 2009, 15:19 -
By pixiecate in forum EditingReplies: 1Last Post: 22nd Oct 2009, 15:08 -
Error loading assest
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Jan 2009, 12:40 -
Getting error loading mpg that svcd2dvd created
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 1st Oct 2008, 13:14
