Hello, I am having a problem.
I am trying to capture four channels of audio and the video from a mini dv tape.
I am only getting Channels 1+2, these are the voice over part of the audio. And 3+4 are music channels, I do not know who or where this tape was made I was just told that these are the channels where each are at.
The problems is I am only getting the two channels 1+2........am I missing something? I can hear all four from the camera (Canon zr70) but not when it gets to premiere (1.5).
Please help & Sincerely,
Craig
after doing a quick google search i found that setting the audio to 12-bit allows you to have a second stereo track in your video...i am assuming when you set up your project profile in premiere you will need to specify 12-bit audio rather than 16-bit....give that a shot and poke around to see if you can tell premiere that it has multiple audio tracks somewhere in the project setup screens.
I tried but It didn't work.
It is just not reading the other channels.
The Standard 32kHz is 12/16 and I cant find a way to adjust it to only 12.
Any thoughts? -
@ Craigmac1977 - Try searching / posting in the forums at www.wrigleyvideo.com/videotutorial
The site has some excellent info on some Adobe video / audio related products. Maybe the forum is as well equipped...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
it is a hardware issue ..
you might have to capture to a type 1 dv file to get around it (and capture twice - once for ch 1 & 2 and 2nd pass for 3&4)
i know premiere can do it in one pass with the DV.Now drivers in type 2 avi.."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
How exactly do I do this?
I don't believe it is a camera issue. I have tried all of the settings in the camera (Canon Zr70) I have also hooked up my xl1s with no luck either.
How do I tell Premiere to "capture to a type 1 dv file" as you recommended.
Please let me know.
Thanks -
If you're still having trouble, you might want to try WinDV - it's excellent, reliable, small, free and can transfer to both DV AVI Types 1 & 2.
It can be configured to produce one continuous clip, seperate clips where scenes on the tape change, and there's even basic command line operability.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Audio Problem with Premiere Pro
By solo_voyager in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2011, 15:43 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 15:16 -
Premiere pro 2.0 export DVD problem
By meekochan in forum Video ConversionReplies: 3Last Post: 21st Nov 2008, 17:55 -
Adobe Premiere Pro 2 Problem
By mymuckaccount in forum Video ConversionReplies: 2Last Post: 20th May 2008, 16:17 -
Premiere Pro CS3 EXPORT PROBLEM...
By REiGN in forum EditingReplies: 2Last Post: 25th Feb 2008, 19:30
