Is there any "easier" and faster way to split an 1 gb svcd mpeg to 2 cds than using tmpgenc's mpeg tools?
thanks.
Well I'm not sure if its faster or easier but there's definitely a better way. bbmpeg is the ONLY compliant mpeg2 cutter/multiplexor I have ever come across. Mpeg2 files cut with TMPGenc do not contain the proper svcd scan offsets which often results in sync problems on many dvd players. bbmpeg seems a little faster than TMPGenc on my system but its not a huge difference. Another advantage though is that you can cut by filesize so you can be guaranteed that you will completely fill each cdr.
Splitting MP4
By rocks911 in forum EditingReplies: 1Last Post: 2nd Mar 2012, 00:11 -
How do I keep DV files from splitting ?
By RWANDREWS in forum CapturingReplies: 3Last Post: 15th May 2010, 04:07 -
Help with splitting
By stinger161 in forum EditingReplies: 1Last Post: 29th Oct 2009, 18:58 -
Splitting Divx
By acestu in forum EditingReplies: 2Last Post: 24th Jun 2009, 21:21 -
Help! Splitting a DVD
By StrikerZERO in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2008, 20:19
