I am tryng to make a web page using Dreamweaver.
I have groups of text that I want the alignment to be justified...(all the lines in the paragraph are the same length).
However, the problem I am having is when you apply this format to a paragraph in Dreamweaver (or Word for that matter) it does not affect the last line...but that is exactly what I need.
Is there a setting that can be changed to make it affect all of the lines?
Thanks.
I don't use Dreamweaver but that is how justified works no matter what application your using. The only way to center it that I'm awre of is cut the last line into it's own
, <div>,....etc and center it. If your using a fluid design that won't work because you have no way of determining what the length of the last line is going to be.
Actually if you do format it like that I think you'll find that it looks oddly out of place. -
Well, it wont look out of place because it is for a menu for my friends bar/restaurant. That is basically how most menus are formatted.Originally Posted by thecoalman
I found a way to get around it but its just a little bit of a hassle.
On the last line after the description of the food you have the leader periods leading up to the price like so...............7.95
So I apply the justify alignment and then add periods in the last line till it is about to the end. I then add an image file at the end of the last line that looks like the background and is as wide as the text block.
This takes me to an extra line which in turn justifies the line with the leader and price.
The extra line with the image acts as the spacer between menu items.
You would think that there is an easier way to do this though
But until something else comes up this is what I will have to do, I guess.
Quick question on css in dreamweaver
By gooberguy in forum ComputerReplies: 0Last Post: 4th Mar 2010, 16:18 -
Editing and syncronising text in virtual dub
By santolina in forum EditingReplies: 4Last Post: 23rd Jul 2009, 17:29 -
editing text in menu in an already made dvd
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2008, 21:32 -
Editing text describing subtitle track in IDX/SUB subtitles
By Chevalley in forum SubtitleReplies: 2Last Post: 8th Jul 2007, 18:18 -
Vegas rolling text question
By RKelly in forum EditingReplies: 3Last Post: 19th Jun 2007, 01:15
