When i encode in DVD 16:9 (avi) i have to tell my TV, this is widescreen.
Normal it autoselect the size !!!
If i take some of the avi files over in popcorn - it also think,
it is 4:3 format ???
I have notice the Video size 720 x 576 on 16:9
and 720 x 544 on 4:3 ( PAL ).
Is this realy the only different, or dont i understand it right ???
Its not a problem to manuel select size on the TV, but why
does all other software, think, its a 4:3 movie ????
I play the files with EyeHome, i know this can be an EyeHome issue.
But i dont think so, because it knows 4:3, 16:9 ect....
Results 1 to 13 of 13
Hi Major,
I just ran across a similar issue. I select a 16:9 source file, use the "DVD ffmpeg" preset, then at the "Video" tab I select "16:9" from the "Autosize" pop-up. In the "Options" tab I have checked off "High Quality," "Two-pass encoding," "Trellis quantization," "Decode with QT ("Letterbox" box is unchecked), then for "Profile" I select "DVD."
The resulting DVD plays widescreen using Apple's DVD Player, but on my DVD players connected to a standard definition TV it shows as 4:3, even if I manually set the players to "16:9" mode. I was hoping to produce a disk that showed full-screen on my standard definition TV, that I could later play at 16:9 when I eventually get an HDTV. Am I doing something wrong, or that's beyond the program's capabilities?
I donated to ffmpegx and love it, but have a few questions
If I always make sure that autosize is DVD 16:9, and letterboxes is unchecked, should I expect it to be in the right proportion on both a 4:3 tv, 16:9 tv and computer media player (like Quicktime or VLC)?
In what circumstances would you check letterboxes, if DVD players automatically add them anyway?
Does the encoding method (eg. ffmpeg not using quicktime) have any impact on 'autoswitching' (I'm guessing it shouldn't).
Thanks,
Bruce
Anamorphic 16:9 DVDs should play on both 4:3 and 16:9 devices. The needed corrections will be dealt with by the player. This is because it is part of the standard, so players have to support it.Originally Posted by broaddd
You would use letterboxes when creating standard DVDs, ie. non anamorphic. They play better on some player as there is no rescaling to do.
Maybe its just me ?? but i dont get it.
If i use the DVD 16:9 option - and take the avi over in toast/popcorn, it still burns the file as 4:3 format - and if i force the 16:9 format, under option - i get black bars on the left and right side of the movie ???? How can i make an avi - that will be burned right (16:9)
I understand what you mean. But this is what toast7 does for me. Simply take any avi, in to toast and burn it as an dvd. With automatic, it burns as 4:3 - if i force 16:9, i get black bars at the sides ???
