    Aug 2005
    israel
    hi good day to everyone
    i downloaded a video and subtitle (.avi and .srt) i want it to convert to mpeg with subtitle then author it to make a dvd can anyone help me with i just taken up this hobby i'm new with all this stuff so please help.
    thanks in advance
  2. Member pchan's Avatar
    Mar 2003
    Singapore
    Depending on what conversion software that you plan to use, you can search here for a Divx to DVD conversion guide.
    https://www.videohelp.com/guides.php?howtoselect=4#4
    If you want a switchable subtitle, then you need a DVD authoring software such as DVDlab Pro. If you want a permanent subtitle, you can just encode into the DVD. In this case, a simple authoring software will do e.g. TMPGenc Author.
    You can get DVD authoring tools here.
    https://www.videohelp.com/tools?s=2#2
    or use an all-in-one tool, thefilmmachine, avi2dvd, diko, divxtodvd(easiest to use) supports srt.
    Aug 2005
    israel
    thanks for the help guys i used mainconcept for encoding and dvdlab pro for authoring and adding subtitles it works fine. theres one more thing hope you can help me the video i downloaded has an aspect ratio of 640x428 (1.50:1) [~3:2] when i encoded it i used 720x576, 4:3 what i wanted is to watch it in full screen without the black bars please help... thanks in advance
