Does anybody know about this player? It has DIVX!!!
http://www.bestbuy.com/site/olspage.jsp?skuId=7288259&type=product&productCategoryId=c...=1118840369037
Results 1 to 9 of 9
Shows Sold Out.. Is it Brand new? Looks like they have just started getting them in the stores.
I saw it tonight. Pretty small, $123 or so... Seems it's new. Couldn't find any reviews on Internet.
Live in Phoenix, Az all the stores here have them in stock, watch out on these Toshiba DVD players hvae owned 2 different models at around this price range both ended up failing within 6 months and the Digital to analog Chips are very noisey, has alot of hiss in them, my best luck have been with panasonic single disk DVD players, just too bad they don't make one that plays Divx, do own 3 of the Philips 742 models that play Divx and thats about all they are good for, playing Divx AVI's, they collect dust except for that, walmart still sells those for $59.
My Toshiba SD-4900 (Region Free, SVCD, etc) has worked flawlessly for a year and does excellent PAL to NTSC conversion. If this new 4980 can be hacked the same way and handles Divx well, it might be a hit!
I just bought this player. Two things you should know about.
1) For some reason in the setup menu you actually have to select component output or they won't work.
2) While it will play DivX from CD-R/RW, it is not gauranteed to, and in my experience, will not play DivX from DVD - R(16x or 8X - tried both Verbatim and Memorex) or DVD+R (Verbatim 16X) -
You can check out these search threads i did on 4980 in the avs dvd player forum. Seems to have so so comments on it.
http://www.avsforum.com/avs-vb/search.php?searchid=2173411 -
same thing happened to my brother in law dvd player.his also didn't last 6 to 8 months.Originally Posted by thxkid
I think the Pioneer PIONEER DV-383S Multi-Zone DVD Player Divx player is a better deal
http://www.amazon.com/gp/product/B000AN5DT0/qid=1127573081/sr=8-4/ref=sr_8__i4_xgl23/1...onics&v=glance
Toshiba SD290 DivX interlaced field problem
By Sainsbo_McManus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Jun 2010, 19:35 -
Toshiba sd-k780 DVD player does not play DivX
By van_d_man in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Dec 2009, 02:09 -
Toshiba SD-185EKB DivX Playback
By antmac in forum DVD & Blu-ray PlayersReplies: 6Last Post: 28th Sep 2009, 18:38 -
What version of DivX does Toshiba support?
By supe in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Nov 2007, 21:03 -
Toshiba SD-34VBSB disc error on divx playback - any help please!
By Bonnybarbie in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 14:38
