In this case the FX is a "film look" filter. I've imported the original avi and its sound track into Vegas and have set up the effect as a track effect on the original avi.
I now want to merge the original avi with its FX and save/export the result as a new avi file that can be edited further. It sounds embarassingly simple but so far I'm not having much luck here.
Any suggestions on how to do this properly will be much appreciated.
Cheers.
It should be as simple as rendering it out as a new avi using File->Render, then loading this back into the timeline.
That said, I would suggest you instead save the FX chain for reuse, then reapply it as needed while you edit the original clip, rather than re-encoding and risking unnecessary degradation. Saved FX chains are very powerful in Vegas now. As time permits I am slowly building a collection of FX chains that mimic some of the better Magic Bullet effects, for as much as I love some of the looks provided, they are unusably slow.Read my blog here.
Hell...you read my mind guns1inger. I've been screwing around most of today wondering why Magic Bullet rendering is so slow. I came across another reference to it as being tedious but with classy results.
Anyway, thanks for your reply and the tip re the FX chain. I'm getting a sense of what you're talking about.
Merge .DTS track with mkv to play on LG BD570 Blu-Ray player
By kcsongi in forum AudioReplies: 2Last Post: 5th Feb 2012, 12:23 -
extract/edit/merge audio track
By skatenglide in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2012, 21:13 -
merge two avi files
By Jorge in forum Video ConversionReplies: 4Last Post: 17th Feb 2010, 22:01 -
merge avi and wav
By zootedlooter in forum EditingReplies: 2Last Post: 21st Dec 2008, 13:11 -
merge avi with double sound track
By facan in forum ffmpegX general discussionReplies: 11Last Post: 22nd Jun 2008, 16:29
