    Aug 2005
    North America
    i am trying to play some avi. files(XviD) on nero, and it does play them. However, it is VERY choppy(stuttering a lot), and there's no sound. It said install the dvd plug-in, so I did. It still tells me to install it, with the problem still not solved. Any solutions?
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Have you tried a different player?
    VideoLan is really good. I use BSplayer sometimes as well.
    Feb 2004
    Australia
    Issue might be related to ac3 audio , so install ac3filters and try again .
    I have not done much work in the avi field for a month or so , but the video may contain aac , nero's mpeg4 type audio format , which wont require installing any plugin .
    Dolby 6 channel audio will require plugin , but avi's dont contain this a far as I can recall .
    Give this convertor a go
    http://fever.link.free.fr/SUPER.html
    Its drag an drop , convert to another video codec or format , same with audio , it might get things sorted .
    Not all video available on the web is done by people knowing what their doing , and some do things deliberately , this is where super can help .
