I just went to author a DVD using a recording I made with my Compro DVB-T300 card.
I thought that the file would be DVD compliant but it says it's a 50fps file (PAL).
If I use DVDpatcher to make it 25fps DVDlab accepts it but playback is at half speed
What should I be doing to get it working ?
Picture quality on the TV was brilliant but it did play back at 1/2 speed.
Back to the drawing board I think! -
You recorded channel 7 HD didn't you! Channel 7, and SBS and ABC use 576p, which is the same resolution as SDTV and DVD, but with 50fps. Assuming the source is film, then each second frame is the same as the last. Simple solution: Record the SD Channel.
Yes, it did turn out to be a HD recording.
Tried SD and it went fine. I love it when there's a simple answer.
Cheers
recording 1080i from dvb-t usb tuner - best practices
By codemaster in forum DVB / IPTVReplies: 1Last Post: 15th Mar 2012, 02:10 -
DVB-t300 schedule recording problem
By sharkbite in forum DVB / IPTVReplies: 0Last Post: 23rd Aug 2009, 18:59 -
Automated recording from DVB receiver card (in Windows)
By Thrasher0815 in forum DVB / IPTVReplies: 1Last Post: 7th May 2009, 08:59 -
Audio Glitches when Recording DVB-TV only
By jfcooper in forum Newbie / General discussionsReplies: 0Last Post: 24th Nov 2008, 03:43 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51
