I was wondering if anyone knew how I can rotate Scene selection buttons in DVD Architect either version 1.0 or 2.0. Thanks.
can you explain better what you mean ? if you mean rollover type effects, or some other change to the look of the button either on focus or on selection, then you need to look at switched menus. there is a tutorial at www.mediachance.com. it is for dvd lab, but theory holds for any authoring package
Read my blog here.
I have the selection button what i want, it's a box...but how do I rotate it so it's at a slight angle?
You can't in DVD Architect. It's tranformations are limited to position and scale. Set them all where you wan't them, export to photoshop, make the changes, then import again. You may have to reset all the links when you bring it back in.
Read my blog here.
Rotating Your Video
By PinkComputer in forum EditingReplies: 0Last Post: 23rd Oct 2009, 09:36 -
Scene Selection Menu in DVD-lab Pro2
By jole in forum Authoring (DVD)Replies: 5Last Post: 25th Feb 2009, 04:20 -
Chapter screens for scene selection menu question?
By ecc in forum Authoring (DVD)Replies: 3Last Post: 17th Feb 2009, 15:49 -
DVD Styler & Scene Selection
By TheKidUn in forum Authoring (DVD)Replies: 0Last Post: 14th Jan 2009, 21:49 -
Create DVDLab DVD Scene Selection Menu
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 09:22
