I have a 700MB AVI Video file in PAL format...
The dimension of it is 496 X 288
Bitrate is 184kbps..
I looked at some guides to do this.. But seem kinda confusing...
I want to keep the dimensions the same as stated above once i convert it to WMV... i would even settle for mpeg too...
anyone have any suggestions on doing this?
What I'm about to show you is actually designed for batch encoding, but nonetheless it will work fine on a once-off basis.
Download Windows Media Encoder 9 and install it. Then extract the files from this zip file (all into the same directory), then edit the batch file so that the input and output directories match your input and output directories. Then double-click the batch file and it will proceed to convert all videos present in the input directory, keeping the same frame size for each video, and using VBR in order to retain the most quality, but reducing the filesize normally quite considerably.If in doubt, Google it. -
Thanks! i will give that a shot. I also have this as a DVD to (in PAL format). What would you recommend I use to make a NTSC dvd from it.
thanks again -
There's plenty of PAL to NTSC guides in the guides section:
https://www.videohelp.com/guides#4;41If in doubt, Google it.
Convert DV-AVI to WMV or MP4
By Black in forum Video ConversionReplies: 5Last Post: 24th Mar 2010, 14:08 -
What is way convert swf to WMV or AVI?
By siluet in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2009, 01:33 -
Convert .mov to .avi or .wmv?
By cielspacing in forum Video ConversionReplies: 13Last Post: 3rd Apr 2008, 14:11 -
How can I convert WMV to AVI or MPEG?
By betlysmith in forum Video ConversionReplies: 6Last Post: 25th Nov 2007, 02:02 -
I need too convert TOO wmv from avi
By theewizard in forum Newbie / General discussionsReplies: 2Last Post: 27th Aug 2007, 20:59
