Hi,
I recorded from tv. The audio from the file is good in the beginning but then it goes out of sync slowely and at the end the sync is ok again!
How can i fix that?
Thanx
recorded to what format?
with what tool and setting?
did you use your pctv rave card? -
i used my pctv rave card. it's an avi and i just want to fix it now...
I know some other ppl allready had this problem and they could fix it... sooo...
Can you capture with segmenting your capture in chunks instead of 1 file. That might help the out of sync. Then rejoin them all later or whatnot.
Quality is my policy. -
if you know other people that had this problem and fixed it, have you considered asking them how they did it ? If sync drifts in and out it will be very hard to correct. The best way I can think of is to load the whole thing into a video editor, cut the audio where it starts to drift, align the new section, and continue to cut and align until you get everything back together. A lot of work. It is not as simple as many other sync problems, such as incorrect delays or format conversions.
Read my blog here.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Good software to add/ sync audio tracks?
By jiopi in forum EditingReplies: 2Last Post: 14th Feb 2011, 08:25 -
Bad audio sync with known good xvid files
By damax452 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 17:22 -
Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of Sync
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 14th Jul 2008, 01:25
