Hi everybody, I am trying to capture some video from my Hi8 camera. I am using a Trust USB2 A/V capture device (I know it's a "toy", but hey, it's affordable) on a 1,2 Ghz pc with about 300 megs of RAM.
I tried several settings to capture (using Ulead video studio), such as uncompressed AVI, huffyuv, mpeg, but I keep getting the same problem: when there isn't much movement, things look nice, but as soon as there's movement in my movie there's a lot of stripes and blocks. The original is fine, so that's not the problem.
Any thoughts?
Thanks!
This is not an optical illusion - it just looks like one.
Try using a low resolution AVI. Your machine is probably choking. Forget about using MPEG.
Originally Posted by hondashadow
Burn a test DVD, Play it to a TV and it should look OK.
If you want it to look better on the computer, invest in PowerDVD or WinDVD. Usually feature reduced versions are shipped with DVD writers.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Duh! I overlooked the obvious. What EdDV suggested could be it as well. The aswer to your question though really depends on the dgree of striping and blocking. Posting a screenshot would help trmendously if the problem persists after you burn a test DVD.
I'll try burning a test on DVD to see how it looks later today, and I'll let you know the result.
Thanks!This is not an optical illusion - it just looks like one. -
Gentlemen,
the interlacing was the problem....
Thanks for all your help!This is not an optical illusion - it just looks like one.
Capturing video from Hi8 tapes
By Thanasis in forum Capturing and VCRReplies: 3Last Post: 1st May 2012, 00:21 -
A few questions about capturing Hi8 tapes with TRV330E
By pericaa in forum Capturing and VCRReplies: 12Last Post: 28th Feb 2010, 19:24 -
video problem at Hi8 capturing
By Dilemma73 in forum Capturing and VCRReplies: 5Last Post: 2nd Jun 2008, 02:52 -
Need a little help capturing hi8 video
By azuberi80 in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2007, 12:38 -
Capturing Hi8 video
By DocD in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2007, 13:46
