I live in Canada and transfered , captured my home made video's into avi nstc file.
I presently made myself DVD's , using Tmpgenc 2.5 or Tmpgenc Xpress and all works well.
My question is , I want to also make dvd's to send to family members in Europe (Italy).
Using my present source captured in avi(nstc).
Do I only need to use the DVD PAl template setting in Tmpgenc, instead of DVD NSTC template?
I was surfing and found some info regarding my question,
I'm just wondering if this is true.
The Topic : I have an NTSC project and want a PAL DVD.
"The good news is: You can just send an NTSC disc. Any PAL set top DVD player capable of playing DVD-R discs can also play NTSC discs. All that is needed is a fairly new TV, built in the last 8-10 years or so.
Do you want to send a VHS tape? Well, since about half of the PAL VCR's are capable of playing an NTSC tape, your chances aren't as good as with a DVD. You still need a fairly new TV, built in the last 8-10 years or so."
[/b]
NSTC to PAL, on Mindv Tape
By poacher in forum Video ConversionReplies: 6Last Post: 29th Dec 2009, 15:56 -
Cant convert Pal .AVI to NTSC DVD in Avidemux
By Hittz in forum Video ConversionReplies: 6Last Post: 5th Nov 2009, 08:43 -
Nstc to Pal
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 9th Jul 2008, 15:42 -
Best 1080P Upconverting PAL/NSTC Region Free Player?
By miamiloco in forum DVD & Blu-ray PlayersReplies: 17Last Post: 29th Nov 2007, 09:37 -
Best point at which to Convert?? (NTSC AVI to PAL DVD)
By junk in forum Video ConversionReplies: 3Last Post: 28th Jun 2007, 17:15
