Hi, i have a problem with these things....
1.VCD=GOOD, SVCD=BETTER and DVD=BEST.....am i right ???
2.I cant use the DVD,PAL layer, it says that it cant do that cause of that the "width*hight* and framerate" are wrong or something like that. Why ???
3.Help me to get the DVD layer to work, cause i want the best quality....
Btw... I have used these (smartripper, DVD2AVI and now TMPGEnc)
Thanks for any help.
What you want to do?
Do you want create VCD or SVCD or DVD?
What is your source? DVD or VHS ?
Do you want to put in CD-R or DVD-R ?
My source is a DVD disc.
I did rip it with Smartripper.
Then i did run DVD2AVI.
Now i want to use the DVD-Layer PAL in TMPGEnc.
But i cant, cause it says that i cant start encoding cause it is something with the "framerate" and the "width and height"
Thats all.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
