They are just like VTS_01_1 etc how do i go about and burn these to create a dvd to watch on my tv. thanks
Results 1 to 15 of 15
Are there bup and ifo files as well?
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Your best bet would probably be using TMPGenc DVD Author (30 day fully funtional trial available). Import your movie .VOBs, not menu .VOBs if you have them (check with Media Player Classic or w/e to see). Then, in DVDA set your chapter points, menu layout, etc, and click on 'output' when ready (either use the built in burn engine, or Nero/etc)..You could probably use something like VOBedit to generate IFO/BUPs for your movie, but it's probably beyond you at this point...And, to be honest I don't use it for this purpose - there is a guide that would help you with the process though.
Tried all that and nothing.. isnt there a guide (ive looked but there are 1000's of guides and i cant find what to do
Change the Extension from .VOB to .MPG and load them in the same order, into Vegas and re render out to DVD/MPG then reauthor to DVD. You need to have all three types of files in the VIDEO_TS folder.
Mind sharing the origin of the files?No DVD can withstand the power of DVDShrink along with AnyDVD! -
so difficult to be a newbie, i also have a video ts to be burned to a dvd and i did not understand anything from any of the replies
, i used dvd shrink to copy dvd to my har disk but dont know how to burn it to a dvd
http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit is all you need.
If in doubt, Google it. -
If you used Shrink to copy this DVD then you should have ended up with ALL the files that make up the DVD structure. VOB BUP IFOso difficult to be a newbie, i also have a video ts to be burned to a dvd and i did not understand anything from any of the replies sad.gif, i used dvd shrink to copy dvd to my har disk but dont know how to burn it to a dvd
I can't see of a way that SHRINK could just do the VOBsNo DVD can withstand the power of DVDShrink along with AnyDVD!
How do I burn Video_TS & Audio_TS files using DVDFAB?
By slayerbizkit in forum DVD RippingReplies: 8Last Post: 22nd May 2011, 20:18 -
very basic question: can I burn a DVD from video_rm & video_ts files?
By glitterla in forum MacReplies: 3Last Post: 25th Feb 2010, 13:09 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 16:43 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 15:13 -
Is it better to burn a VIDEO_TS folder or a MPG file?
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2007, 17:54
