Hi
When converting a avi file to a ntsc dvd format
there is an option where i can chose interlace or not
can you tell me what does this mean
what should i choose to have better compatibility result with a home dvd player
regards
Results 1 to 11 of 11
Any video intended for playback on TV should be captured and encoded as interlaced. Deinterlacing it will reduce the quality, even make it appear choppy.
Take a look about 1/4 of the way down the page:
http://www.digitalfaq.com/dvdguides/capture/understandsource.htm -
Because the results will be a little better if you leave it progressive.
If you take a non-interlaced source and convert it to interlaced MPEG2 for DVD, the MPEG encoder will split the two fields apart and encode them separately. This results in more blurring of the colors (although this is usually very subtle) and less efficient compression.
The general rule: interlaced source -> interlaced MPEG2 for DVD; progressive source -> progressive MPEG2 for DVD. -
I would answer that last question with "not necessarily".
This is one of those situations where answering one question leads to many others. To understand the answers you have been given, and the reasons why, you really need to round out your knowledge base.
I would start with reading some of the definitions and guides available on this site, the answers are already there. The reason they are there is that questions like this get asked several hundred times a year.
The answer you have not gotten yet is that you should leave interlaced for TV playback and de-interlace for PC playback, generally. A few minutes of reading will tell you why. -
And just add to that good DVD playing software such as PowerDVD odes a great job of deinterlacing on the fly during playback negating the need to deintelace for computer playback.Originally Posted by Nelson37
The only time I deinterlace video is for video that is going to be distributed on the web such as website. Many people are not going to be viewing your video through PowerDVD hence the reason to deintelace.
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 03:33 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
VirtualDub De-interlace
By Lee82 in forum EditingReplies: 16Last Post: 25th Feb 2008, 19:57 -
Interlace confusion
By Bagshot in forum Capturing and VCRReplies: 7Last Post: 16th Feb 2008, 09:46 -
Interlace or Progressive??
By Browncoat in forum Newbie / General discussionsReplies: 9Last Post: 31st Jan 2008, 16:14
