I have a movie on my HD, which is in .iso format, how can i convert this to a mpeg, avi or .vob file? and
i burned a .vob file into a DVD+RW and its playing on a standalone DVD player, but you can here the people talking but after few seconds you can see their mouth actually moving. how can i fix this problem?
Thanks a lot, this my first post, be nice to me.LOL
Results 1 to 9 of 9
resko, oher, macedonia
ISO is not a format, it's a disc image, and it can be literally anything that can be burnt to disc.
You need to extract whatever it is you have - see https://www.videohelp.com/forum/viewtopic.php?t=233348 for assistance - then take action depending on what it is you actually have.If in doubt, Google it. -
i did manage to use the DAEMON tools, and i extracted the files. I am trying to use Nero Express to burn the files to a DVD+RW ( the files wer AVSEQ01, AVSEQ02) but after 30 minutes it says" unable to create structure"?? any idea what might couse the problem?Originally Posted by mr_coffeeresko, oher, macedonia
Sounds like you have either a VCD or SVCD inside the ISO - check https://www.videohelp.com/vcd#struct and https://www.videohelp.com/svcd#struct to see which folder layout matches what you have.
Then read this:
https://www.videohelp.com/forum/viewtopic.php?t=129786If in doubt, Google it. -
If you're going to burn to a disk anyway why bother extracting anything? Just use Nero's burn disk image function.Originally Posted by resko
Batch convert ISO to AVI/Divx/MPEG
By extrememc in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2010, 19:13 -
Using ffmpeg command line to convert a .vob(DVD) to avi/mpeg
By alfo666 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2009, 04:14 -
DVD/vob/mpeg to Avi/xvid automated process, Help!
By sinz in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 02:08 -
VOB/Mpeg to AVI??
By Rjupiter in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2008, 09:00 -
vob to iso?
By jree1 in forum Video ConversionReplies: 8Last Post: 20th May 2007, 12:12
