Hi,
I am after a free software program to cut up and make my own samples from dvds/cds etc
The easier to use the better
Plus it would be cool if it could change the eq
Cheers
Aaron
Hi angryassdrummer,
Look in the "Audio Editors" category in the "Tools" section - you can list them by type to put the freeware ones at the top.
Audacity might well meet your needs...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
you can use dvdshrink to rip out a part and then convert it to wav. and read https://www.videohelp.com/forum/viewtopic.php?t=205836
Any automated method to cut 45 second samples from audio tracks?
By ian_g in forum AudioReplies: 3Last Post: 17th Jun 2011, 12:22 -
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 09:17 -
Make samples ?
By yabbah in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2009, 06:41 -
Command line tool to make x264 mkv samples
By lime- in forum EditingReplies: 4Last Post: 1st Nov 2008, 16:58 -
Using sound samples in audio/video production - short tutorial
By lmemsm in forum AudioReplies: 0Last Post: 1st Sep 2007, 09:05
