I have this system: Panasonic SA-HT800V
I recently encoded a surround sound test I made in Dolby Digital Wav format using BeSweet, and then burned it to a CD, but when I played it, the dolby light didn't light up, the speaker indicators stayed at Left and Right, and I just heard the pulsating static like when one tries to play the wav file without a decoder.
I happen to know that a DTS-WAV works perfectly, so what is wrong with the DD-WAV decoder?
Thanks in advance!
Hiho,
for me it sounds like your DVD-player tries to handle this PCM-like DDWAV like a normal 16bit44.1KHz as usual on CD-Audio (infact it is one but needs to be decoded), DTSWAV contains a simular type of WAV but your player doesn´t touch it -> your amp do the decoding job.
Possible solution:
unplug your analog chich kabels (black(or white) and red) and leave only your chinch digital kabel and/or your optical TOSLink connection plugged.
-> what could happen: your amp won´t get a wrong decoded signal - only the (un-)decoded AC3 - maybe he would decode it by himself
Which do you prefer - Dolby Digital or DTS?
By yoda313 in forum PollsReplies: 48Last Post: 17th Apr 2014, 23:49 -
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 8Last Post: 31st Mar 2013, 22:31 -
Is Dolby Digital HD/DTS HD on Blue Ray better than Cinema sound?
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2008, 00:32 -
Select Dolby Digital 5.1-ch, DTS 5.1-ch or both?
By coody in forum DVD RippingReplies: 6Last Post: 17th Feb 2008, 21:22 -
Does Divx contain the Dolby Digital and DTS sound.
By sam9s in forum DVD RippingReplies: 8Last Post: 11th May 2007, 16:37
