Results 1 to 14 of 14
  1. Hello i have 2 dvd+dl they only contain files not movies!
    When i try reading them in dvdclone or dvd decryptor nothing works!
    When i clicked on cdclone it read it and saved it??
    Not sure what to do??
    My sony dvd burner supports Dual Layer.
    I have ordered some dvd+dl discs and need to be able to copy these two discs....wil clonecd copy onto dvd+dl
    thanks
  2. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    If they are just files on the DVD+DL media, then you can just drag and drop them to a folder on your computer......then re-burn those files when you get more of media in.....
    What We Do In Life, Echoes In Eternity....
  3. What do i use to burn the media onto the dvd+r DL discs?
    thanks
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Oh...sorry didn't get thats what you were asking....I use copytodvd. Try the newest version of dvddecrypter to rip, and burn. What program came with your burner? If it is a dual layer burner it should have came with some form of software..
  5. Member ice-berg's Avatar
    Oct 2003
    Cold as Ice
    The newest version of clonecd does handle DL.
    if you want a free software that also delivers good quality dl burns then you could use dvd decrypter, however you would have to convert the files into one ISO image (since decrypter only burns iso).
  6. Just use Nero ("DVD Copy" option) or some other burning software that can burn DL discs. 8)
  7. ok,i cant drag and drop them to a file,it says it will take like 180 minutes then after about 30 minutes it gives an error something like a cycle redundancy check?
    Tries copying and pasting them no luck either,same problems.
    Im using windows xp
    So back to my original question....how can i copy these?
    My dvddecryptor doesnt seem to reognize there is even a disc in the drive.
    Clonedvd doesnt make the disc spin up either.
    When i click on dvdshrink then the dvd drive takes off but dvdshrink gives an error also(something about file type)!
    What would be the best program to read the info on the discs and save it to a file for burning later?????????
    I didnt get any software when i purchased the dvd sony dual layer burner.
    Do i need software for the burner itself?
    I went back and re-read everything...guess whats confusing me is clone(cd)not dvd.........didnt know you used clonecd to clone a dual layer dvd?
    Myclone (cd) seemed to read and save the images just fine!
    I thought it was just scewed up as i didnt have any of this media to try and see if it really worked or not.
    Maybe all i well?
    thanks for the advice!
  8. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    Cyclic redundancy check.
    Is your DVD scratched or damaged?
    got the latest firmware for the device? updated ASPI?
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  9. If its just data, it sounds like your data is corrupt.
  10. It is just data but the dvd's are new!
    no scratches or anything!
    I went back to clonecd which i used to read and save,just for kicks i though i would put in a cd disc and try and burn it,seemed to burn it just fine but when i put it in my drive to read...nothing happens!
    When i put a regular dvd+r in and try using clonecd to burn the image it saved i get this error.
    Clonecd
    Value must be between 1 and 2147483647
    i need help!
    I assume if i had a dual layer dvd media to try and burn this maybe it would work????
    Feb 2004
    Pleasant Hill, CA
    I haven't tried DL DVDs yet, but I used burnatonce and the ProDVD add-on last night to burn a data DVD+RW (already using DVDDecrypter for ISO/movie burning).
    My ulitmate goal is to burn DL discs, but I finished up at 3AM, so figured I'd continue when I had gotten some sleep
    Info on burnatonce and ProDVD can be found here:
    http://www.burnatonce.com/index.htm?faq
    click on "DVD General".
    Hope that helps,
    Jim
  12. I still dont have a clue what software to use to copy these dvd+r DL media that have data on them?
    Also what software to burn them as well?
  13. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    you tried Alcohol 120%?
  14. not familiar with it?
