hi all just wondering if someone can tell me where the plugins for nerovision express are kept i had problems trying to burn some vob files because i didnt have the dvd plugin picture no audio.
but got it via a message on here. but would like to know what plugins i do have if someone can tell me.
also is there another burner that will burn vob files as i have tmpgenc dvd author but says vob files are invalid format
thankyou for any help
More likely that your serial is not enabling it than it not being there.
ok but where are the plugins stored or how do i know which ones i have so i can get the ones i need
they used to be stored in a plugins folder under the main nero folder. Chances are you will only see .dll files and may not be able to determine exactly which belong to what plugin.
CopytoDVD will burn DVDs, as will DVD Decrypter once they are in ISO format. However if TDA says they are invalid I would be concerned that they are not completely to spec and may not play correctly once burned.Read my blog here.
They are stored in (from recollection) program files\common files\ahead\audio plugins and if you right click it should give you a description under properties. Probably a mix of .ax and .dll files.
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 17:32 -
MPEG2 stored in Matroska questions.
By nateo200 in forum Video Streaming DownloadingReplies: 1Last Post: 27th Nov 2011, 12:53 -
How is data stored on DVR?
By howdoesthiswork in forum DVD & Blu-ray RecordersReplies: 8Last Post: 27th Oct 2010, 19:18 -
Capture picture stored on a DVD
By casualdvdmaker in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2010, 07:36 -
VLC choppy video playback/Nero Plugins
By RippingFlesh in forum Software PlayingReplies: 5Last Post: 3rd Jul 2008, 09:16
