i recently got an error " unmountable boot volume" and this problem proceeded when i found it that the computer would freeze during the XP cd installation, it freezes exactly after i press "R" or "ENTER" with it saying "Examining 76348 MB Disk 0 at Id 0 on bus 0 on viasraid..." it is a SATA drive and i do press F6 for it to detect the drive
i really need help thanx
Have you tried any third party utility that can examine/repair the disk, like Parition Magic? SOunds like your Master Boot Record got messed up. If you can manage to get to the recovery console, try running : fixmbr.
You can also do:
fixmbr \Device\HardDisk0, but fixmbr assumes your boot drive.
When you hit F6, does it successfully locate and load the SATA adapter? If so, your hard drive may be on the verge of dying.
Also, try connecting the drive to a different SATA port on the mainboard/PCI card. You may have to go into BIOS and turn off SATA1 and turn on SATA2 (assuming device assignments).
Hope this helps. -
thanx a lot for replying, this is all new hardware from less than a year ago, i cannot access recovery, the xp disk boots up but as soon as i press R or ENTER the computer freezes, i installed the HDD on my other pc and it worked formated it from there and was working fine, got the same problem when i reintalled it into my other machine, could this maybe be the mobo?
ohh and i forgot yes it detects the F6 drivers when im installing it
Restore old fim, please point me in the right direction for start (picture)
By PlayWithFire in forum RestorationReplies: 41Last Post: 11th Jul 2011, 16:09 -
PC freezes at start up even on new hard drive?
By Denvers Dawgs in forum ComputerReplies: 34Last Post: 11th Jan 2010, 23:48 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 00:35 -
undeletable start-up screen?
By CuriousYellow in forum Authoring (DVD)Replies: 3Last Post: 16th May 2009, 23:10 -
Having to reinstall files each start
By SeveralButchersApron in forum ffmpegX general discussionReplies: 9Last Post: 2nd Apr 2009, 18:10
