    Apr 2005
    Alaska
    I captured an HDTV video (Dick Tracy) from my Motorola 6412 cable box via Firewire and CapDVHS to my PC. And yes, my cable company knows ALL about it. I'm legal! I have the extention set to ".ts". I edit and convert the clip using HDTVtoMPEG2. I check the resultant .mpg and all looks fine. I have (among other apps) Nero 6.6.0.15 including the 5.1 plugin. After adding the clip to NeroVison Express 3 I have a light gray bar on the bottom of the clip. I have TMPGEnc 3.0 and know about using "mask" but that will kill my ability to produce a 5.1 disk.
    On some clips there is no problem but others have had lines at the top or bottom as this one does.
    WTF?
    I appreciate your help as I've been screwing with this for weeks and have decided I must have done too much LSD in college afterall cause I can't fix it...
    Wolf
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Are you sure you are getting 5.1 AC-3 on that port? I don't think I am but haven't looked closely.
    What HD ts viewer supports 5.1 AC-3? I'm looking for one.
    PS: I think the line at the bottom is a byproduct of deinterlacing 1080i but I'm not sure. Try interlace.
    http://www.kiva.org/about
    Apr 2005
    Alaska
    The port delivers 5.1 when the source is broadcast with it. I haven't tried to verify it on my PC but the DVD's I've authored using Nero and that Multichannlel plugin appear to deliver 5.1. I use VLC Media Player or Media Player Classic most of the time.
    Uh, "try interlace"? Where is that toggle?
    Wolf
  4. Member edDV's Avatar
    Mar 2004
    Wolf
    So you are making 480i DVD?
    I can't explain where the line comes from. It sometimes shows with VLC viewer.
    Still not sure of AC-3 on the port here. Will look later.
    I'm not sure of Nero for this. I rarely use it.
    Consider yourself a pioneer.
    Apr 2005
    Alaska
    I have been unable to resolve this problem. Any ideas people?
    Wolf
