Looking to do some voice over work on our vacation DVD this year. Any advice on model/type is greatly appreciated. The budget for this is $75-$100 USD.
Good mics connect with 600 ohm balanced XLR connectors. You will need a small mixer like Behringer Eurorack UB502 to adapt those to a PC line input.
http://www.worldmusicsupply.com/pro-audio/audio-mixers/Behringer/UB502.asp
This is an amazing bargain and much better and cheaper than anything you would find at a Radio Shack. $34+shipping leaves you a ~$50 budget for a new or used mic.
http://www.worldmusicsupply.com/mics/vocal.asp
Or, if you have a camcorder, you can use its mic for voiceover and connect the audio to the audio card line input.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
get your self a used Shure SM58 or SM57 and the above mixer.
I've just been down this path, tried a whole range of electret junk with cheap pre-amp - no good. Have just purchaced a Yamaha MXL 'Desktop Recording Kit' - high quality Condenser Mic, self powered (battery), with connection lead to a mini-jack. Works exceedingly well !!
Very interesting, I want one.Originally Posted by JohnP
http://www.digitalvideoediting.com/articles/viewarticle.jsp?id=33810Recommends: Kiva.org - Loans that change lives.
Some very good suggestions. Had read some very positive things about the Shure SM58 & SM57 regarding their musical usage but wasn't sure they were good for voice over work. Good to see that is correct. Question on the DRK: given the fact that the power source is a 9V battery, will this unit go through batteries quickly?
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 21:11 -
How to Change your Voice to another normal Voice
By UmmAddan in forum AudioReplies: 2Last Post: 21st Jul 2011, 18:00 -
LG HT 305SU (MIC IN / MIC OUT Problem)
By iamjamal in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2011, 17:38 -
Re: low cost mic fro voice dubbing?
By tomcat862 in forum AudioReplies: 8Last Post: 8th Apr 2008, 03:41 -
free software for adding voice through mic to vcd
By andreytenov in forum EditingReplies: 4Last Post: 12th Nov 2007, 04:20
