What Mac tools are the best for replacing the crappy menu on DVDs recorded using my LiteOn LVW-5006...Sizzle?...Forty-Two?
The LiteOn makes nice discs but I would like to add a better-looking menu with links to the chapters. I do not want to reencode anything - just build a better menu, but I don't have the funds for DVDSP. I have iDVD and an old version of Toast 5.2. Can the old versions of Toast do this?
Results 1 to 10 of 10
If you have OS 10.3.9 or later, QuickTime 7 and a G4 or G5 processor, then get Toast 7. It has 10 menu designs and does chapter menus, unlike Toast 6. The only downside is that Toast 7 will place chapters in time increments from a VR-mode DVD rather than let you select their location. If your LiteOn recorder lets you place specific chapter marks on a video-mode DVD then Toast 7 will use those markers.
Another option is to get CaptyDVD 2 which is available bundled with a couple LaCie products. I was told by LaCie that the lite version can also be purchased for $75 by calling LaCie. It will let you use existing MPEG files, has customizable menus and you can select chapter marker locations. Unlike Toast, it takes some work to do all this, though. It works with any version of OS X and with G3 processors and above.
Even with CaptyDVD you'll still need Toast 7 or PixeVRF Browser to copy the MPEGs from a VR-mode DVD. Otherwise you'll have to use the video mode format when recording with your LiteOn and finalize the disc before it can be read on the Mac. -
If you use Cinematize you can copy all of the video straight to quicktime and then import into iDVD
Converting to QT and then using iDVD really is a bad option since you loose quality and the amount of time it would take.....ugh.
You only choice if you have VR discs is to use Toast 7, or VRF Browser. Toast 7 is much better and cheaper then buying VRF and Capty DVD.
If the discs are recorded in Video mode, then Cinematize and Toast 6 or 7 would work. You should save as a program stream from Cinematize. -
Perhaps I'm looking at this from the wrong direction. While Toast 7 will allow me to build a new menu, it costs more than I feel like spending (I haven't seen a lower upgrade price from 5->7 yet). The LiteOn LVW-5006 can be used to build a better menu by manually selecting "edit" with the remote at the points you want to have new thumbnails...and I haven't explored what I might be able to do with DVD+RW media on a PC.
Originally Posted by cbkilner
It has 8 or 9 tacky menu themes and, unfortunately, you can 't use your own backgrounds or buttons.
Toast does allow you to auto-play the disc and to play all of the files continuously, as a single movie, so you don't even need a menu, but I wish that you could drag and drop a background image to a menu like you can do with SIZZLE...
Dave -
if you don't want to spend any money, you might be able to design your menus with whatever ap, then build a generic menu in sizzle, then open the generic menu build in pgcedit, then in that ap, import in your footage from your liteon dvd and then re-author in pgcedit.
i don't know sizzle so i dont if building a generic menu dvd is possible. and i'm new to pgcedit. but i htink you'd be able to pull this off. pgcedit, runs in x11. info below, with instructions on how to install. if you've never installed stuf under x11 before it looks like a pain, but wasn't really that hard.
https://www.videohelp.com/~r0lZ/pgcedit/
i've done the above with another ap, tfdvdedit, and it works, but i htink you could substitute pgcedit for tfdvdedit.pants on, pants off, pants the floor. -
Create custom menu styles in Toast 7.
Found this tip the other day, but not yet tried it out yet.
http://www.macosxhints.com/article.php?story=20050828135331105#comments
how to reauthor features from 2 discs w/ menus intact
By lockonx in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2011, 03:08 -
any free tools to resize/clip mpg2 and add black borders?
By extent in forum EditingReplies: 4Last Post: 16th Dec 2009, 17:23 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Add Subs to DvD With Menus
By zoranb in forum MacReplies: 0Last Post: 9th Nov 2007, 04:23 -
i add subtitle to a dvd and the coulor after reauthor is black!!!
By siopilos in forum SubtitleReplies: 1Last Post: 18th Jul 2007, 21:19
